Is there any way how to load spline points from file according to parameter?
For example I have files with points:
points_1.pts
points_2.pts
and I want to load file points_1 when I set some parameter to 1 or load points_2 if parameter is 2... and so on.
The reason for this is that I use ansys workbench with creo and need to change geometry from workbench according to parameter value. The geometry is precalculated in the files.
Thanks for help
best regards,
Michal
