start asm template relations
thlavinka
1-Newbie
I have following relation in start asm template:
/*CONTROLLING CALIPERS RAL2004
if NAME=="CONTROLLING CALIPER"
RAL="2004"
endif
then I have a parameter CUSTOMER
i would like to add another reralion(s) like this:
if CUSTOMER is "JD" and NAME != "CONTROLLING CALIPER"
RAL="5018"
if CUSTOMER is "VL" and NAME != "CONTROLLING CALIPER"
RAL="5008"
else
RAL="5012"
can anybody help to make it work?
Thanx in advance
T.
1 ACCEPTED SOLUTION
Tomas,
simply replace your relation with my. It must work correctly.
  /* NAME is equal to "CONTROLLING CALIPER"
  RAL="2004"
else
  /* NAME is not equal to "CONTROLLING CALIPER"
  if CUSTOMER=="JD"
    RAL="5018"
  else
    if CUSTOMER=="VL"
      RAL="5008"
    else
      RAL="5012"
    endif
  endif
endif
MH
Martin Hanák
4 REPLIES 4
use following relations:
  RAL="2004"
else
  if CUSTOMER=="JD"
    RAL="5018"
  else
    if CUSTOMER=="VL"
      RAL="5008"
    else
      RAL="5012"
    endif
  endif
endif
MH
Martin Hanák
Hi Martin,
Thanks for your quick answer.
There is a problem with CONTROLLING CALIPER - if the parameter NAME is CONTROLLING CALIPER the RAL must be 2004 no matter which the CUSTOMER is.
T.
Tomas,
  RAL="2004"
else
  if CUSTOMER=="JD"
    RAL="5018"
  else
    if CUSTOMER=="VL"
      RAL="5008"
    else
      RAL="5012"
    endif
  endif
endif
MH
Martin Hanák
IT WORKS...
THANKS A LOT
