summary text file line into proe
Highlighted
Newbie
Hey group.
I didn’t receive any replies only O.O.O. replies so I suppose that it is not possible. Please see the original post below. I sent this across on Friday before the 4th holiday. I am hopeful that it has overlooked due to the holiday vacations and stuff and that maybe it really is possible. Naturally I will re-summarize if I receive any useful information on this subject.
TEW
Original post
Is it possible to display or report in a drawing table or region a string of text that is a specific line number from a text file? Is it possible to parametrically link notes down to a specific line number?
For instance if i have a text file with several lines of text: How can i tell pro to display just a single line or set of lines in a drawing or in a table, and then also be able to create a similar note using a different set of text lines. Is something like this possible? Or does one have to display the entire note text file?
TIA – summary will follow.
Tracy
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
