text file line - into proe
Newbie
Apologies for the double post to those users in both the draft and model forums:
Is it possible to display or report in a drawing table or region a string of text that is a specific line number from a text file? Is it possible to parametrically link notes down to a specific line number?
For instance if i have a text file with several lines of text: How can i tell pro to display just a single line or set of lines in a drawing or in a table, and then also be able to create a similar note using a different set of text lines. Is something like this possible? Or does one have to display the entire note text file?
TIA – summary will follow.
Tracy
