thru hole without the word THRU in the callout
flaporte
Can I get a callout for a thru hole without the word "THRU" without erasing the word manually?
1 ACCEPTED SOLUTION
dnordin
(To:flaporte)
If you're referring to standard (spec driven, UNC, UNF, ISO) hole callouts, you can customize the note callout via the .hol files.
See http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/index.html#page/pma/part_modeling/part_nine_sub/Formatting_Thread_Note… for help on editing the .hol files to customize the note callouts based on hole feature options.
Dan N.
BenLoosli
23-Emerald II
(To:flaporte)
Check your settings because I created a new part, added some holes, created a drawing  and when annotated, only got the diameter symbol and the diameter value.
Creo 2 m220
dnordin
(To:flaporte)
Dan N.
Thank you Daniel, it was precisely what I needed!
