trail file of pro/e
Newbie
trail file of pro/e
hi, guys
here is my problem.
I want to connect pro/e with modefrontier by using trail file. So I first define some parameters in pro/e. However, in the trail file, there shows no parameter name just some numbers.
Does anyone know how to modify trail file, in order to define parameters?
here is a part of my trail file:
~ Command `ProCmdMmParams`
~ Activate `relation_dlg` `ParamsPHLay.TBAddParam`
~ Key `relation_dlg` `ParamsPHLay.ParTable` \
5505140
4718696
524296
524296
4259937
5111918
4653159
3211313
~ Disarm `relation_dlg` `ParamsPHLay.ParTable` \
2 `new_added_row` `name`
5898362
3211313
~ Activate `relation_dlg` `PB_OK`
!Undo: added rec_id 327 type 5204
11 REPLIES 11
Re: trail file of pro/e
There are some tweak settings in config.pro to change the default behavior of both reading and writing trail files. I think by default it just picks screen locations. I have very little luck with running trail files.
Thanks for you reply. But is there any chance to change this? Have you ever connect pro/e with modefrontier?
Thanks, this is very important for me.
my suggestion is to add the following option into config.pro file
new_parameter_ui no
Restart Creo/ProE and you will get old user interface for managing parameters. Try to create a parameter and look into trail file. Maybe you will see reauested parameter name.
Martin Hanak
Martin Hanák
Yeah, it did work. Here is still the question, I still cannot connect pro/e with modefrotier using the trail file of pro/e.
Could you give me further help? I will be greatful. Thanks.
Is it possible for this sentence " `<VAR name="R" format="0.0000E0"/>`" to appear in the trail file?
modeFRONTIER has an integration with PTC Creo.
http://www.esteco.com/modefrontier/ptc-creo-parametric-integration-node
Examples from the supplier
http://www.esteco.com/customsearch?keys=proengineer&field_resource_year_value=
It doesn't look like trail files are a good method for linking modeFRONTIER to Creo.
I can't help you, because I do not know modefrotier.
Martin Hanak
Martin Hanák
All right, thanks
I know this method. I'm not sure if this method could export geo model and connect icem.
Then I would like to import the mesh file into fluent. That is to say, I need to connect modefrontier with pro/e, icem and fluent.
Can this method work what I mention?
Thanks.
