turn off annotation display by default
Participant
Can someone tell me how to turn off 3D Annotation Display by default?  Every time I open an assembly the Annotation Display is set to show.  How to I set it to Hide when I open a file?
Re: turn off annotation display by default
Go to File - Options - Entity Display and find "Show Annotations and Annotation Elements", uncheck the box and when you push OK, it should prompt you to if you want to save the settings, choose yes and *hopefully* you will have a config.pro you can save to.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Thank you!
