unit tolerance in Creo 6.0
SkyKing
7-Bedrock
How do I do unit tolerance in Creo 6.0?
15 REPLIES 15
I have this same question but for Creo 4.0.  Where the heck is it?
Please elaborate further on what you are trying to, the steps you are taking and the resulting behavior.
Thank you.
Amit
See the image below.  It's the "Per Unit Tolerance" check box.  I'm trying to apply a tighter flatness tolerance to an area of a part.
How do you do below in Creo 4.0 and up? Below is from Creo 3.0.
Thanks!
I guess what the customer has is wrong. Because Creo is more up to date with standards, GD&T is more controlled. Per unit basis not compatible with profile geometric characteristic.
We use it for flatness, not profile.
SkyKing
7-Bedrock
(To:RCorley)
Did it work out for you?
I swear it used to work.  But now it doesn't again.  Any ideas?
SkyKing
7-Bedrock
(To:RCorley)
Manually do it has a text or error the red!
What do you mean by "error the red"?
SkyKing
7-Bedrock
(To:SkyKing)
What version Creo 6.0? It works for me, I have Creo Parametric 6.0.5.0.
Thanks for checking.  It's Creo 4.0.  It works on another drawing/model I have.  It just doesn't for this one.
SkyKing
7-Bedrock
(To:RCorley)
I wish they would just improve things, not change things around!
