unit tolerance in Creo 6.0
Regular Member
How do I do unit tolerance in Creo 6.0?
9 REPLIES 9
Re: unit tolerance in Creo 6.0
I have this same question but for Creo 4.0.  Where the heck is it?
Please elaborate further on what you are trying to, the steps you are taking and the resulting behavior.
Thank you.
Amit
See the image below.  It's the "Per Unit Tolerance" check box.  I'm trying to apply a tighter flatness tolerance to an area of a part.
How do you do below in Creo 4.0 and up? Below is from Creo 3.0.
Thanks!
I guess what the customer has is wrong. Because Creo is more up to date with standards, GD&T is more controlled. Per unit basis not compatible with profile geometric characteristic.
We use it for flatness, not profile.
Did it work out for you?
