using d values to get the sum between to two.
cncwhiz
I have a drawing table that has all of its values comming from the part. I want to take and &d - &d to get the value in my drawing. I have tried relations and I am getting errors. This is what I am trying to get to output the correct valve in my table "(&d1044-&d1043) plus the corner radii *2. How can I do this?
Terry
Create a relation that could be named sum such that the equation would be
sum=d1044-d1043+radii(need the real d#)*2 make sure you verify relations before closing relations tool window.
Then call out the parameter sum on your drawing.
Regards
In Reply to Terry Thomas:
Eric Mills
Design and Project manager
http://www.rapidoconsulting.com
eric.mills@rapidoconsulting.com
Or put the sum parameter in your family table in order to show it in a
drawing table if there is more than one value that will need to be paired
with other values for different instances.
There is no way to short cut the system to put the actual formula in the
drawing table, in the on screen notes or to overwrite a reference
dimension. You have to take it a step at a time and do the relations in
the relations editor and pass that information in to a parameter then call
out the "new" parameter.
Brian S. Lynn
Technical Coordinator, Product Engineering
