var sec sweep
Highlighted
Newbie
var sec sweep
Hi there...
From my earlier email this morning I can expect many OoO reply, but it
might worth it...
Is there a way to use a curve "From file" into a variable section sweep
command? In fact, I have a profile defined by an IBL file that I want to
extrude following 2 lines. The enclosed image present the expected result,
but I succeed only when I sketch a spline directly into the sketcher of
the var sec sweep command. It must be a way to replace the sketched spline
by either: 1) a use-edge applied on an existing curve or 2) a sketch "From
file"...
Any idea or clue will be appreciated,
Thx,
David
Highlighted
RE: var sec sweep
David,
Try, saving the sketch off as a "save as" (.sec) then open a new sketch.
The sequence you want is Sec Tools, Place Section, your save section
will be in whatever folder you saved to. Simply follow the prompts from
here.
Hope this helps.
Brad Juchno
Power Medical Interventions, Inc.
2021 Cabot Blvd. West
Langhorne, Pa. 19047
267-775-8105
267-775-8122 Fax
bjuchno@pmi2.com
www.pmi2.com <http: www.pmi2.com="/>
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
