Performing a 5 axis cutline machining and trying to smooth out the vector tool axis changes. The interpolation between 2 points is too jumpy or has wiggle. I would like to improve this
The machining has a high quality requirement and I have very small scallop and tight tolerance on the sequence. Does this also impact the vector movements?
For my axis def I am using points of srf, location, axis. I have spaced these points out evenly around my cutlines. . Is there a best practice for the amount of points to use?
How about specific parameters that control the vector, such as ANGULAR_TOLERANCE what is good setting here? Or does not apply.
All thoughts and comments appreciated. Thanks
Eric,
Although other CAM softwares in the market already supports toolpath discretizationfor a long time, Pro/NC will only support it from WF5.0 onwards.
What you can do to reduce such issues is to define the LINTOL parameter for these sequenceswith a very small values, as 0.001 or 0.0001 (I use these values in mm - Please convert them to inches if necessary) - You can make some tests to find the ideal value for your applications.
Asmall value in LINTOL willforce Pro/NC to generate extra motions which may help youwith these issues.The PP must will also handle with the linearization differently, and this may help you substancially.
From Pro/NC help:
"LINTOL
Allows you to specify the linear tolerance interpolation used by post-processor, for multi-axis milling and Mill/Turn rotary linearization. Outputs the "LINTOL / r" statement at the beginning of the CL file. The default LINTOL is a dash (-), in which case the LINTOL statement will not be output. "
If you are experiencing serious problems, you may contact Fred Nemecek at Austin NC (www.austinnc.com) orKent Hanson at Post-Pro (http://post-pro.com/aboutus.aspx)
Both them are very experienced guys regarding Pro/NC posts and I´m sure that they may help you out.
Daniel Santos - Sr. NC Programmer / CAM Support
Liebherr Aerospace Brasil
WF5.0 Enhancement:
Control for 5-Axis Surfacing Improved: http://www.ptc.com/appserver/wcms/relnotes/note.jsp?&im_dbkey=78491&icg_dbkey=826
enable_absolute_accuracy= yes
Last but not least, it is important to stress that none of these tips alone are really effective. The key is to use all them together.
A quick start for better surface finishes and dimensional accuracy and better GCode:
* Get a good post processor - If your control offers HSM functionality, it is important to issue the proper code in the GCode to take advantage of this capabilities.
* Work with absolute accuracy whenever you can - I personally use to set it as 0.001mm - This is the smaller increment I can program on my controls. In Inch I would use 0.0001" as most of controlsworks with this accuracy level.
* If working in multiaxis mode, use LINTOL. I use to set it as my absolute accuracy/maching tolerance.
* Use small tolerance values in general, unless you are roughing. This is specially important for 2D strategies based on surfaces (Profile milling / Trajectory using surfaces instead of chains) - I use to set it as my absolute accuracy as well. - Pro/NC will generatearcs whenever is possible...
* And of course, get WF5.0 as soon as it becomes reliable andan option. Then you can use toolpath discretization...
HTH
In Reply to Daniel Santos:
WF5.0 Enhancement:
