Why would the relations automatically truncate in the first image, but not truncate in the second image?image 1
image 2
Sometimes it won't wrap until the model is closed, removed from session, and reopened. Does doing that make any difference? What about saving a copy?
good observation but I have tried removing from session with making slight changes between:
It is very annoying because when the truncation occurs you can't just highlight the newly seperated lines that make up the right side of the equation and evaluate them. You must first re-format the equation to be only one line then you can evaluate it without getting an error.
Sounds like a bug. Maybe open a support case if you have it. If not, let me know and I will open one.
I opened one but the guy just told me just to put it down as a product idea and hope it gets voted on.
Case #13901571
Grrrrrrr
Push back. Ask him to explain why some truncate and others do not. Ask him to prove to you that the behavior is working correctly.
Good thinking.
I just added a comment to the case.
If Creo is working 'per spec' ask to get a copy of the spec.
Don't hold your breath waiting!
Hey @TomU I think I have figured out what is going on here.
Man that took a while to figure out. I even had the PTC support guy share his screen so I could walk him thourgh how to do it.
On top of all of this, it was never a problem in Wild Fire, so at some point there was a regression of functionality.
This has been very costly to my company and I sure hope that the R&D department can find a solution for us.
So what did you find out? Why do some wrap and others do not?
Upcoming October 2019
Regional User Groups
