Re: Performance Advisor for PTC Creo
TomU
First, it normally only sends data once per day. This is controlled by prefs.xml located in <install location>\DiagnosticTools\text\xml
You can force it to send immediately by deleting the contents of the "unprocessedFiles" and "SentFiles" folders.
Second, from what I can tell PTC's website also only updates once per day. You can see this on the top of the details pages.
18 REPLIES 18
Marco_Tosin
(To:TomU)
Tom,
I'll wait until tomorrow and see what happens.
Thanks again
Marco
Marco_Tosin
(To:TomU)
It's been two days from my previous comment, but nothing has changed.
Marco
TomU
(To:Marco_Tosin)
I have a bunch of users who haven't shown up yet either. Guess I need to go do some investigating...
Marco_Tosin
(To:TomU)
Here in Italy we say "mal comune mezzo gaudio".
In english I have found this translation "trouble shared is a trouble halved".
Marco
TomU
(To:TomU)
Okay, I've stumbled onto something. Take a look at the files in the "SentFiles" folder. Inside each of the .zip files is a "PTC_Creo_Parametric_3_0_M030.xml." file. See if there is a section in the file called "<PTC_Creo_Parametric_Session_Logger>". If this section isn't there, no information will appear on the reporting site.
Now to figure out why this section is missing in all the recent files...
TomU
(To:TomU)
The "Session_Logger" section is created AFTER Creo is closed down. (Which actually makes sense since it lists the start and stop times of that session.) Local installations of Creo are properly creating this. Network installations are not. Hmmm.
Marco_Tosin
(To:TomU)
We have two network installation of Creo.
One is the working installation of Creo 2.0 M140, the other is testing installation of Creo 3.0 M030, which we'll start using in 2/3 months.
Following your instructions I see that xml files in the "SentFiles" folder, those of version 2.0 doesn't have the section you described, while those of version 3 have it instead.
But anyway in Thingworx dashboard nothing appears.
Marco
Marco,
just a warning concerning CR3 M030 & repeat region bug ... see https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS200179
Martin Hanak
Martin Hanák
Thanks Martin.
Have a nice day.
Marco
TomU
(To:Marco_Tosin)
I have opened a case with tech support. You may want to do the same.
Marco_Tosin
(To:TomU)
OK.
If I'll get some useful answer from TS I'll post it here.
Marco
Hi Marco,
I see you mentioned that your xml files from Creo 3.0 M030 appear in the 'sentfiles' folder, which indicates that they DID get transmitted to PTC. It sounds like you do not see this data in your Performance Advisor for PTC Creo dashboard. This could be related to SCNs; I will check and see if the SCN used in the Creo session, matches the SCN for your web account.
Stay tuned!
PS - please correct me if you are not seeing the Creo 3.0 M030 xml files in sentfiles, only Creo 2.0 M150 (and later), and Creo 3.0 M030 (and later) will display in the Performance Advisor dashboard.
- Dan
Dan,
thanks for your answer.
Yes, as you wrote, my xml files appear in the sentfiles folder, but I can't see them on the dashboard.
I check my SCNs in the license and xml files and, as you can see in attached images, they coincide.
Marco
TomU
(To:Marco_Tosin)
Marco,
Everything is working correctly now. The issue with the missing data in the XML file was due to my inadvertently putting a development build of Creo 3 (M030+) into production. Once I realized that and rolled back to M030, everything started working correctly again.
As far as Dan's comments about the SCN, you can check this yourself. The SCN is included near the top of each "PTC_Creo_Parametric_3_0_M030.xml". Compare this value to the one shown when you're logged into the support site. (I can see our SCN when creating a new support case.)
Marco_Tosin
(To:TomU)
Tom,
thanks to your suggestion, I realized that in my account privilege for PTC Advisory was not checked.
Now I check it.
See attached images.
After that I Open Creo 3.0 then sent manually my XML files, but nothing appear on the dashboard.
Remembering that you said that is updated once a day, I'll check it tomorrow.
Marco
Hi Marco,
We found an issue on the PTC side. We patched your account, and i will file an SPR for a full scale fix. Can you please check the dashboard again, and let me know if you see your data now?
- Dan
YES!
Thanks a lot Dan.
Marco
