Hi Bob,
This is what I get in (good old) Mathcad 11:
I don't think this does anything different from what you are trying.
Possible pdesolve in Prime is not yet up to standards.
I've attached my sheet. Try to create an html file from it, using the...
View more
Hello EveryoneGood Evening, I am facing problem in logging properties there are some values which are repeating after I carry out the experience multiple times.PFA attached image in which arrows are shown on the readings which are repeating when I co...
View more
1. How can I search for each frequency range?For example I looked into the excel file and I saw that 1kHz begin from line 61536 and is ended at line 62560:
Therefore I extracted manually the respective range in Mathcad:
So, for...
View more
Hi,I am having issues working with the pentable when I set the pentable file and all 3 config options, but still, while printing and saving the pdf file, the geometry lines are not as per the pentable, and when I remove the pentable file, geometry li...
View more
