Adding Bend Machine Data on Pro Engineer Drawing
ShailendraHasab
I have created the pipe/tube in pro piping. I will get the report of the pipeline as belows. But unable to put this data on my drawing. Request to please let me know how can i add this tube bend information on drawing. Bend Machine Information ======================== Bend # Offset Twist Angle Bend Angle Bend Radius ------ ------- -------- -------- ------- 1 349.03 0 65.56 1.50 2 300.59 208.56 37.97 1.50 3 1190.37 113.58 56.13 1.50 4 953.79 0 0 0 Thanks & Regards, Shailendra Hasabe Tel: +91 020 6633 7314
Hi Shailendra Hasabe ensure 1. that standard coordinate system of the "piping assy" is located at the starting point of the pipe (including flange if applicable). And 2. that z-axis of this coord-sys is oriented towards the pipe. Information concerning tables, repeat-reagions, and piping-parameters are available? Other questions about piping? Regards Gerald gkaufmann@cad-cones.de www.cad-cones.de
and one thing else.... you need to analyse your pipe concerning these informations e.g. via the info-menue. Regards Gerald
Thanks Gerald for useful information. I could not know correct parameters for repeat-reagions in table for Bend Offset, Twist Angle, Bend Angle and Bend Radius. If you inform me then it's better for me. Thanks...Shailendra
Hello Shailendra Hasabe Have a look into Pro/Help search for "Parameters Applicable to Pro/PIPING" here you find parameters to report them in tables. To fill up table cells double-klick into the cell of the repeat region and follow the menue. There is no adding of "&" or further editing of the cells necessary. Regards Gerald gkaufmann@cad-cones.de www.cad-cones.de
