Hi, everyone.
I'm trying to find the recommended process for adding a cable to a splice. I'm running Creo 3. Here's the setup:
Is there a simpler way to do this? Can't I just "add" the cable to the splice, just like I can add it to a bundle? Select the cable, select the splice, and done.
ETA: It seems that the method above doesn't always work. Can't get it to work now. Any tips?
[Ignore. Edited the main post instead.]
No takers, huh? Guess there's no way of adding a cable to a splice, except deleting the splice, routing the cable and then adding the splice again. That gets pretty complicated when you have some cables that need to be routed to the splices and some that need to go through.
