Cable bend radius analysis
Moonstone
I can create an idea for this if it isn't already possible. I don't do a lot of cabling so maybe it is.
Is it possible to do an analysis to figure out where in your harness your bend radii are the tightest? I tried changing my bend radii and the cable fails but there is no way for me to easily see where in the cable it is failing.
Ideally there would be a color plot showing the cable curve and color varying with the tightness of the bend.
Re: Cable bend radius analysis
Yes, that’s certainly possible, and we have code written to do so. We can pull whatever information you need out of a harness. Drop me a line at Phil.clukies@cadactive.com to learn more.
