I used Pro-Cabling/Pro-Diagram for many years (10-12) with both Wildfire and the initial releases of CREO. I am with a new company and trying to sell them on parametric harnessing (for many years they have used line entity drawings in Autocad and manually filled tables).
I have been running a trial of Schematics/Cabling and have eaten up much of the trial simply getting things functional. I have zero references to use to prove this out, as my previous employers files were proprietary.
I have my connectors placed and bundles routed and split as necessary (pic below), but the out of box library is missing so many spools I cannot make the proper schematic. The schematic I want to do would be pretty basic. I have placed my connectors using the connector groups but cannot find any reference for 2 node splices and cannot figure out how to change connector node from numeric to alpha (for 23 pin Deutsch HD). If I had something to go from, I am confident I could stumble through it, but I'm a bit overwhelmed with the changes to the Cabling and schematic modules made since I used it about 5 years ago.
I've done some digging here and really am not finding much (surprisingly) and what I am finding, the uploaded files have expired and are not acquirable. Does someone have a schematic, model, flattened mfg file, and parametric drawing with connector tables/BOM/CDT/etcetera that they can share? or can someone point me to where to find this?
Thanks in advance,
Kevin
