I am wondering if there is a way to easily show your network layout to other people, before adding wires and splices etc.? The network is not too bad, but in thin wire mode it is not highly visible. Would be nice if you could quickly make it all solid. Or even, more likely a possibility, a config setting to make the network appear thicker.
This would allow evaluation of routing at an earlier stage of the design.
