Cabling with Multiple Cable Assemblies
dthoma25
2-Guest
Good afternoon,
I am having trouble routing multiple cable assemblies (different cable assembly models) through the same locations such that they pack appropriately.
I basically want to send 4 cables through 2 P clamps such that they stack on top of each other at specified locations (round not flat).
I am using Creo 4.0 and my assy structure is as follows.
Top level model
-W100 (first cable .asm model)
-W200
-W300
-W400 (fourth cable .asm model)
Is there a technique to route/pack 4 separate models?
1 REPLY 1
I would recommend using shared networks between your different harness parts. You can create a network in W100 and share that network for the 3 following harnesses.
http://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/electrical_design/cable/using_networks_to_route_cables.html
John Piotrowski, Co-Founder & Product Manager
CadActive Technologies - www.cadactive.com
