Can anyone provide a good example of the dg_inherit_from_connected function?
Highlighted
Regular Member
There is very little documentation on this.
I have a simple block (in wiring diagram) with 5 ports on it.  Each port has a Label attached to it (labels are not attached to the block but to the ports)
I run single fibers to each port.  I want the Port to grab the "color" parameter (or any parameter) from the wire and that calculated parameter will be pushed to the text label.  It should be easy right?
Thanks in advance!
Patiently waiting....
