Code for connector/parent id in cross sheet graphics
Level 9
Looking to a way to indicate the location of the other end of fibers using cross sheet graphics that does not use the row/column text.  Some uses of our designs do not keep the border with the rows and columns shown.
I am looking to use something like P21-A SHEET 2 or K12 P21-A SHEET 2
We use a hybrid design system where K12 is the parent of connector P21 and A is the port id within P21.
We require that the designers NOT duplicate the connector numbers, so just using that and the port will identify the connection location but adding in the component would make it easier for the user to find it on the design.
