Copying a view & draft entities to multiple sheets - WF2
Newbie
I'm doing a cabling diagram.
Just using colored splines on one sheet, then I want to copy this view
with all it's splines
to produce 1 sheet for each harness.
What is the easiest way to do this?
Snapshot the whole view then copy, or maybe just reproduce the view then
copy the splines?
Which way would be less memory intensive?
Mike
