Correctly displaying wires in a drawing
Newbie
Hi All,
I have an assembly that uses Pro/Cabling to create some wire harness. I am
facing problems in correctly displaying the wires in the drawing module. See
the attached image. I want to know if there is a way to make the entities
'behind' ( Meaning contained within the lines that represent cable) the
cable to disappear so that the cable appears solid. Is there any dwg set up
for this?
I am using Pro/E 2001.
Thanks in advance,
Jaya
Re: Correctly displaying wires in a drawing
full_hlr_for_cables. Settings are FULL, PARTIAL & NONE I believe
Partial is the setting you are
looking for.
Malagi, Jayateertha (GE Consumer & Industrial, consultant) wrote:
> Hi All,
> I am facing problems in correctly displaying the wires in the drawing
> module. See the attached image. I want to know if there is a way to
> make the entities 'behind' ( Meaning contained within the lines that
> represent cable) the cable to disappear so that the cable appears
> solid. Is there any dwg set up for this?
> Thanks in advance,
> Jaya
