Creo Schematics BOM report
Regular Member
Hi all,
I can not make BOM (list of electrical component) in Wiring diagram in Creo Schematics. I need on sheet list of all component and their sum (like a mechanical BOM). Is it possible in Creo Schematics create BOM report? If yes, can you tell me how?
Ludek
Tags (3)
Re: Creo Schematics BOM report
Hi
Choose Inventory
Assuming you want to display name and then report on something that can report total for example Part number set the inventory column priority
You will then get the total for part number 123 (2) next to each unique entry of name
If you remove name and uncheck inventory column
the you will get the following results - 123 shown once and with a qty of 2
hope that helps
jim
