Hi everyone!
I've just started to use PTC Creo Schematics 3.0, and I have a problem with routing fibers. I'd like to place wires simply, without the catalog selector dialog box opened every time. So if I would push the route fibers button, it would place the same (for example: sample wire) every time, and I would define the specifications for them later from the database. I saw a tutorial video, where the place fiber button was blue by origin, and the designer placed wires like I described. In my case the button is black/grey and the catalog selector opens every time I push it. What kind of settings do I have to do to route wires without the selector dialog?
Best regards from Hungary!
Lac
Lac
If you have lots of fibers in your catalog and you want a button for each fiber than you can record a trail, create a custom command and add the custom command to your Ribbon
the video will demonstrate all the picks,
i hope that helps, Jim
Lac
Hi Jim!
I can see the video now, yesterday I tried to watch tutorial videos on learning exchange, and I realized I didn't have the proper flash player installed.
So, this trail recording could really solve my problem, like shown on the video, but I have to ask about the "blued" route fiber button.
I saw this blue button, in the previous version if schematics (2.0) as I realized, the video I watched was made with the 2.0 version. Is it possible to manage this blue button in schematics 3.0?
Thank's!
