Creo Schematics to Drawing.
Srini
Hi, I know this is not logical but still I am curious to know is there any way which we can have the Cable /wire list information on the drawings with out routing in Creo cabling. I got this question by seeing recently that in Creo Schematics 2.0 we are running term tables and because of this most of the information required for this table like Wire number, Connector, spool, From, To, etc information is available in XML file, except the length of the wire. So by assuming that I don't want to know length of the wires, is it possible to show the other information on the Creo Drawing.
gkoch
(To:Srini)
As far as I know, we can only show information about the physical routing in report tables, not the logical information it is (usually) based on.
gkoch
(To:Srini)
Srini
(To:gkoch)
Thanks Gunter
