As per your experience what is the design turn around time if you use Creo Schematics and Creo Parametric for Harness?
Complexity | ||||
High | Medium | Low | ||
Definition | Number of Wires | greater than 60 | 20 to 60 | less than 20 |
Number of Connectors / Terminals | greater than 30 | 10 to 30 | less than 10 | |
Number of accessory components (Clip ties, grommets, ferrite, etc) | greater than 15 | 5 to 15 | less than 5 | |
Turn Around time | Harness design first time creation | |||
Harness design modification |
