Anyone using EZRouter out their? I have attempted to use EZR when it first arrived and yesterday. Not so easy to me. I put mega hours into Harness routing which seems much easier. Is this just a matter of getting used to EZR? I have forced one flex Hose to conform to the route I wanted but it did not react the way I was hoping, so I routed it thru points which turned out much nicer. 2001 old build 2003090
EZ router is really a easy tool to use I found it vary fast and intuitive until I wanted to change one point, It would move the whole route with it, so I only use it for a fast layout work. You will be better off with good old points to drive your route. I have also used reference geometry the same way I use them in harness it works but points are more power full. Douglas A Bowles <-> wrote: Anyone using EZRouter out their? I have attempted to use EZR when it first arrived and yesterday. Not so easy to me. I put mega hours into Harness routing which seems much easier. Is this just a matter of getting used to EZR? I have forced one flex Hose to conform to the route I wanted but it did not react the way I was hoping, so I routed it thru points which turned out much nicer. 2001 old build 2003090
