Enhancement Requests for Creo - Summer 2013 TC Meetings
SOLVED
Highlighted
Re: Enhancement Requests for Creo - Summer 2013 TC Meetings
Hi John...
I understand this issue well. I think what's happening is that the model is actually regenerating but the pattern instances are failing. The little red "stop light" at the bottom of the window is supposed to alert you to the fact that there are failures. You should see a small box at the bottom which pops ujp in the event of a pattern failure. the box should warn you that some features failed to regenerate. Is this not happening for you?
Thanks!
-Brian
Highlighted
I agree Burt.... absolutely ridiculous. I'll bring it up today.
Highlighted
Hello Everyone...
The link to the completed document (spreadsheet) tracking all enhancement requests is UP! This has all of the requests I've gathered from January of 2013 (last year) through January 2014.
There's quite a bit going on in this chart... the color codes help explain what happened with each submission. The dots in the first column appear next to any item that has been updated for January 2014. As promised, I went back to the old lists. If I'd missed something from Jan '13 or June '13, I tried again in Jan '14.
Over 80 enhancements from your submissions did get in front of the PTC developers. Many of them were well received. Some of them were either already planned, already implemented, or so popular that I imagine we'll be seeing them very, very soon.
Everyone who submitted a request should check the chart for their name and add comments to the DOCUMENT thread so I can add keep track of everything. I'm only linking the document here for convenience. Please submit your comments and feedback to the document thread so I don't have to hunt through the longer discussion threads to see your responses.
Thanks!
-Brian
PS: I'm adding this same note to all 3 enhancement threads so please forgive the duplications!
Highlighted
Brian,
Can we add request to make possible to choose table color under System Colors-Graphics menu. Currently, color for tables is defined by LETTER option which is the same as dimensions' lines. Same request goes for hatching.
Thank you.
Highlighted
Hi Brain,
I have one suggestion for enhancement request in Creo
Whenever the Family table instances are called in Drawing BoM, only instance are available though 2Dregion, but generic part is not added.
There are work around suggested by Tech support, but not the exact way to go for.
Once the BoM table is created, it sould contain Generic part and all its intances.
Amit
Highlighted
Amit,
Good suggestion. However, the 2D region should give you the option of including or excluding the generic or any of the instances. Sometimes there are instances (or the generic) that you don't what shown in a table.
Tim
Highlighted
If possible - can this thread get closed? There's already a January 2014 TC enhancement request that is also out-of date.
Highlighted
Agreed David, thanks for the suggestion. I've locked this discussion since it appears to be out of date. Any new enhancement requests should be submitted using our PTC Creo Product Ideas area.
