Enhancement Requests for Creo - Summer 2013 TC Meetings
SOLVED
Re: Enhancement Requests for Creo - Summer 2013 TC Meetings
Hi Danilo,
In general this is a very good list of concerns. Many of them I am very familiar with
Brent
Hi Brian,
Unfortunately I am not going this year
I have four suggestions that I made back in 2010 for WF5 and I have updated for Creo 2.0
These are Powerpoint slides made into PDFs which I hope to upload here (fingers crossed)
Brent
OK so seems I have to do them as images.
Extrude Enhancement #1
Open and Closed sections in External and Internal Sketches for Extrude
Brent
Extrude Enhancement #2
Tree Enhancement
Brent,
Thank you for the hint, but, as you said, it does not fix the most annoying thing: resizing columns. Who knows, maybe in Creo 250 it will be solved.
And finally (for now)
RMB/Menu Enhancement
Happy commenting
Brent
Oh yeah,
ou can see in my examples I use the pre WF color scheme. As was suggested I have tried the default scheme in Creo 2.0 (as I did in WF5) but did not take to it.
Yes I am a dinosaur from back to R14 in '95 but that is not the reason. I find the lack of contrast with "modern" pastel and off white schemes hopeless for doing concentrated work.
Brent
Have a look at the attached file, Brent... it has a hidden command in it for pre-wildfire color scheme:
USE_PRE_WILDFIRE_ENTITY_COLOR YES
No one would answer what this meant when I opened a case for it but I use the attached file with very good conformity to my old 2000i scheme.
I like your suggestion here. I'd say that perhaps what is needed is better, or more grouping. As more items have been added to the RMB menu, the list has gotten longer. Logical grouping would be helpful and consistent placement of items that are common across menus would be helpful.
LinkedIn
