Eplan - Pro/Cable integration
vmcdaniel
2-Guest
I believe that the RSD to Pro/E integration is done through XML.
Anyone ever heard of Pro/Cable and Eplan integration?
We use Eplan but would lobe to drive Pro/Cable with it.
8 REPLIES 8
We are struggling with the same problem. Did you find any solution for eplan integration?
We did not find a solution.
Hi, I worked for a client recently and they worked in eplan while the mechanical guys were in CREO. I can't say it was very successful form a CREO point of view and to be honest I think the electricians did whatever they wanted. They did however generate a 3d eplan assembly that could be dropped into CREO. The biggest issue was the scale of the job was way beyond what had been attempted before.
We are also looking for EPlan 2D schematics integration to Creo through XML, any inputs on that? i saw some video for SolidWorks
To my mind EPLAN is working for an cabling data Export to Creo.
If you need informations you can contact me.
sxu-3
(To:vmcdaniel)
The principle should be similar to RSD.
But it is not a few words can say clearly.
It's the same principle,
Im- and Export via XML Structures.and an addon for EPLAN P8
sxu-3
(To:vmcdaniel)
The key is how to define attribute in EPLAN
