I'm new to Pro/Cable and I am unable to open a harness flat pattern. The message I get is "Cable harness cannot be retrieved in this mode".
I don’t have any floating modules available, the harness-mfg and diagram are part of our package. I proved this to myself by creating a new harness from the cable part.
This cable was outsourced originally, and the person that knew it best at my location is no longer here.
Anyone know why I can't open the flat harness?
I should have mentioned, it is the assembly that I can't open. There are two assemblies in session, the titles have XXX_fr.asm and XXX_mr.asm and I cannot open either one.
One message is "Harness manufacturing assembly cannot be retrieved in this mode" (XXX_mr.asm)
And the other message is "Cabling harness cannot be retrieved in this mode" (XXX_fr.asm)
I don't know the significance of the naming.
The answer is open the .mfg file to get the flat pattern.
Thanks to all that responded.
Michael,
Also note, that there is a config option in WF3 and above that has to be set to be able to open the XX_MR.asm.
Here is that option:
! Allows the *_MR01.ASM to be opened in assembly mode
allow_harn_mfg_assy_retrieval yes
Cheers,
Frank Mohr
Caterpillar Inc.
