How does one pack a design in Creo Schematics 3.0?
SOLVED
Highlighted
Newbie
The only reference in the Help is a Command Line Option. Our Windchill is not integrated to Creo Schematics and we pack the designs to travel around.
Tags (2)
1 ACCEPTED SOLUTION
Re: How does one pack a design in Creo Schematics 3.0?
To pack the design Creo schematics 3.0, Go to Save a copy > select the file type as a packed design(*.rsd)>Click on Save.
4 REPLIES 4
File, Save a Copy..
Found it.
You might look at "Backup".  That copies everything you currently have in an assembly to a single folder.
That is no longer needed in Schematics 3.  It will work to both write and read the single .rsd file for designs.  Saves the work of copying or zipping up directories.
