Hi friends. I'm researching that how to create helical cable in cabling. I found a method but it's not practical.
My method is;
Disadvantage of this method, there are too much points (about 50-100) and ı have to select these one by one. (can't select as a whole by shift key).
Do you know another method (and more practical) to create a helical cable in the cabling application. Help Please?
There is a lot of good information in this thread that should be able to help you with this problem.
http://communities.ptc.com/message/244276#244276
Thanks, Dale
