How to make a wire/fiber splice in creoShematcis 2.0
schampagne
Hi everyone,
I am new to Creo shematics and I have troubles making a simple splice on a wire. I precisely followed the indications in the doc page "To Insert a Splice" with no success; the cursor does not become "T shaped" as it is supposed.
I use creo schematics 2.0.
Any help/advice would be greatly appreciated.
1 ACCEPTED SOLUTION
you need to create block (with proper diagram type) which include three ports organized as following :
  • two ports are on the same horizontal plane with opposite directions (one point to the right and one point to the left)
  • 3rd port should point downwards, should be located in the middle between above ports ( in the same horizontal plane below)
  • datum point should be located at the intersection point of all three ports
  • for additional info, you can read the doc page "To Set a Branch Shape"
Video Link : 5033
Gaby
Video Link : 5033
Gaby
Thank you very much for your answer.
Is it possible to use a single dot style, like the documentation example in the section "About Splices"?
yes, just place the ports one over each other.
vegazva
(To:Gaby_K)
Hi, Unable to fine the video
