I have a number of different parts using a same sketch (a ,sec file), I want all of these parts updated when I may original sketch is modified. Is there any way to do this? Is import sketch from file system the way to go?
Can I modify the original sketch (the sec file) and then get my part updated? Will the changes made to the original file be reflected on the part using the sketch?
For example I am designing a housing for a circuit board. I want to have a board sketch and use it in multiple parts, e,g, housing top, housing bottom, and some internal components. I want all of these parts updated based on the modification to the board sketch. Is there any way to do this?
Thanks in advance.
