Is it possible to change an alredy placed cross sheet graphic
SOLVED
Amethyst
We have multiple versions of cross sheet graphics and sometimes a wrong one has been placed.  Is it possible to change one that has been placed without removing the connection and starting over?
1 ACCEPTED SOLUTION
Highlighted
Re: Is it possible to change an alredy placed cross sheet graphic
Bill,
Select port (you can use port selection) and on the Diagramming tab under Replace Shape the pull down has Replace Port Shape.
1 REPLY 1
Highlighted
Bill,
