JAVA API
ptc-6306282
6-Contributor
JAVA API
Sample Code:
I'm looking for some sample code written in JAVA 1.7 to interface to schematics. I want to update a parameter
on an artifact that I have in the schematics using JAVA. There are really no examples to follow. I would be happy with the standard "Hello World" code just to see if I could get the code to work through the gateway interface.
1 REPLY 1
BillF
(To:ptc-6306282)
Have you looked at the Java samples that come with Schematics.
Hello World would be covered in a standard Java course other than that the results are displayed in a standard output in a command window.  Schematics' API has commands to write to text windows in Schematics.
We just had Martin from CeDel Solutions (https://www.cedelsolutions.com/component/option,com_contact/Itemid,3/) present a class on how to write Java to a number of our users and programmers.  We had him teach several topics:  Basic Java, Schematics Java API (documented in a PDF file in your Schematics installation), and code that he previously wrote for us along with help on a current project that we are writing.
