Looking for Table (.tbl) files (for cabling)
SOLVED
Highlighted
Regular Member
someone have the following table files handy that they can upload?  Thanks in advance.
circuit data
bom
connector
splice
bundle
1 ACCEPTED SOLUTION
Highlighted
Re: Looking for Table (.tbl) files (for cabling)
Some of those tables are in your loadpoint.
My folder location is C:\Program Files\PTC\Creo 4.0\M090\Common Files\text\table
Your's will likely start some differently but will be basically the same
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Highlighted
I found this, but would like to avoid making new tables from scratch if possible.
Thanks in advance for any input
http://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/electrical_design/harness/harness_...
Highlighted
Steve Williams
Highlighted
and so they are!
Thanks a ton!
