Moving Intralink Data Server
Highlighted
Level 1
A few questions:
Is there any way to compact the intralink Dataserver? Sort of an ldbcompact for commonspace...
If there is not, I will be forced to move my Dataserver, preferably to another drive on the same server (I won't be moving the file vault). From what I've been able to find in the archives, I should be able to do this by creating a dump file and I should be able to get the new Dataserver running before I remove the current Dataserver. However, will having the new Dataserver on the same machine as the current one cause problems? Is there anything I'm missing?
Rob
NT 4.0
Intralink 3.0 2001200
Dataserver and Fileserver on the same machine
