Need to add parameters to thousand of drawings, parts & asm
shiwangi
Is there any way to add parameters to multiple files at the same time or some way to automate it?
Currently I am working on Creo 3.0 & Intralink.
You can use ModelCheck or DBatch - but those are a bit painful to setup and debug (in my opinion).
IF you want a quick solution - use CREOSON
Here is a code example (slightly modified) from the PlayGround in CREOSON that creates/sets the same parameter across all prt files in session using a wildcard (e.g. *.prt) . -- you can do the same for assemblies and drawings just change the wildcard extension.
let paramObj = new creo.ParameterObj();
    paramObj.file = '*.prt'; //  <<-- ENTER CREO FILE and EXTENSION (can be wildcard)
    paramObj.name = 'NEW_PARAM'     // Parameter 'name'
    paramObj.value = 'HELLO!'        // Parameter 'value'
    paramObj.set();
If you want to do the same for ALL Parts in a Working Directory by loading each model into memory one at a time.... you can do something like this (modified from the sample code in the CREOSON PlayGround):
function setParam(itemName) {
    paramObj.file = itemName;
    paramObj.name = 'NEW_PARAM';
    paramObj.value = "WOW!";
    return paramObj.set();
function processItem(itemName) {
    let fileObj = new creo.FileObj();
    fileObj.display = true;
    fileObj.activate = true;
    fileObj.file = itemName;
    return fileObj.open()
              .then((itemName) => {
                  return setParam(itemName)
function batchFiles () {
    let creoObj = new creo.CreoObj();
    let creosonUtilObj = new creo.CreosonUtils();
    creoObj.filename = "*.prt";  // <<-- ENTER CREO FILE (*) and EXTENSION
    creoObj.list_files()
        .then(function (respObj) {
            return creosonUtilObj.loopItems(respObj.filelist, processItem)
        .then(function () {
            alert("Finished Batching!");
        .catch((err) => {
            alert('ERROR: '+err);
// START THE BATCH PROCESS!
batchFiles();
Note the above code leave everything in session within Creo - so you would have to add a save operation after each update to be more complete.
Hope that helps!
Dave
