Opening Pro/Cable created harness assemblies
I am trying to work on a wiring harness that was created using the Pro/Cable module, but I am having difficulty in opening the .asm file that is associated to the drawing. I do have the cable, diagram, and harness-mfg modules active in my session. I can open the drawing, .prt, and .mfg files but not the .asm. When I try it says it cannot be retrieved in this mode. Any help would be appreciated. Thanks, Joel
