I'm looking for a best practice on how to branch a pipe at both ends... see the attached example.
The sketched line needs to branch at both ends of the existing pipe - the resultant solid pipe should be cut at either end to match the od of the existing pipe. Does anyone have a well tested method for doing so?
Thanks in advance,
Paul
