Pro/Cabe question
NormanMelanson
1-Newbie
Pro/Cabe question
Hello all, I'm fairly new to Pro/Cabling and need a bit of help. Is it possible to create 1 cable assembly (*.asm) using multiple XML's from RSD, to create 1 flattenned harness design to eventually create 1 nailboard for this cable assembly?? For example, imagine a an airplaine's electrical harness assembly which consist of multiple cables, harnesses and individual conductors, that would run from one end to the other of the airplane, and which would be 1 part that is manufactured, on a nailboard in a shop somewhere, then eventually placed in the airplane. Is it possible to do this in ProE? If yes, how?? Thanks, Norm.
3 REPLIES 3
CBenner
(To:NormanMelanson)
I suggest you join (if you have not already) the PTCUser group discussion forums. There are several individuals there who are familiar with Pro Cabling. I've used RSD for Piping, but I know nothing about cabling. http://portal.ptcuser.org/p/st/ld/sid=s1_001
Chris Benner
Autodesk ® Expert Elite
Thanks, will do...
Hi all :I am a newer to the proe/cable.I delete the cable from the asm,but I can not select the linker that had be used next time. who help me sovle the question.
