Hello all, I'm fairly new to Pro/Cabling and need a bit of help. Is it possible to create 1 cable assembly (*.asm) using multiple XML's from RSD, to create 1 flattenned harness design to eventually create 1 nailboard for this cable assembly?? For example, imagine a an airplaine's electrical harness assembly which consist of multiple cables, harnesses and individual conductors, that would run from one end to the other of the airplane, and which would be 1 part that is manufactured, on a nailboard in a shop somewhere, then eventually placed in the airplane. Is it possible to do this in ProE? If yes, how?? Thanks, Norm.
