I am using WF4.0 Pro/Cabing (without importing logical refs from a diagram). I know that when you route and terminate both ends of a multiconductor cable and then go to MODIFY > PARAMETERS > and select the cable it brings up 'Electrical Parameters' dialog box with a 'FLIP ENDS' button that allows me to change the 'From' 'To' and so therefore I can control what REF DES displays in the connector 'From' 'To' columns as I intend on the drawing wire run list table. My question is...How do I change the 'From' 'To' if I routed by terminating each conductor out of a multiconductor cable on both ends (instead of just terminating the cable ends only)? The 'FLIP ENDS' doesn't appear using that routing method for some reason, but I am sure the cable constuctors are 'Completed' (or terminated to 'Entry Ports').
I assume other folks must have come across this already and hoping somebody can help.
