Pro/Manufacture Harness Connector Question
Newbie
I have successfuly routed and flattend a harnes I've
laid out, the problem is that I haven't been able to
assemble the connector at the ends. While under
#flatten#Components#Assemble, the system prompts for
"select location to assemble connector to"
I pick a location at the end of the cable and the
system returns the following error
"Component/connector at location(id = 29 in harness
DATAPORT2INTERFACE_HARN) is not in session".
Can someone help me figure out what this means?
Thank you
