Pro/ piping Question
Newbie
I am trying to self learn Pro/ Piping. I got a book and did the exercises. One of them was using a flexible hose. I set the coordinates, added the start and end; it draw a flexible hose that moves if I slide one of my parts. Is there anyway that I can move the house manually, like dragging it? Any help will be appreciate it. Kevin Stark
Re: Pro/ piping Question
You can still add some intermediate datun points and route the pipe through those points. This will help you to modify the routing of your pipe by just editing the X,Y,Z values of the datum points. This may help you.
Pro/Piping Question
In the Piping Route menu there is Insert point functionality.Choose your flex hose and you can move/drag it manually depending on the reference you select.
LearningExchange has some tutorials that may be perfect for you, including Flexible Hose topics.
http://learningexchange.ptc.com/tutorials/search?product_id=&search=pro%2Fpiping
